export waveform to spreadsheet
Jon,
No problem at all.
Best of luck with your app.
Regards
Rob L
NI Applications Engineer
UK & Ireland
It only takes a click to rate this message 😉
Message 21 of 24
(1,424 Views)
Do you mind if I ask one last question? I have been told now that they want all the data to be processed in Excel for them (someone has been giving them ideas...). To tackle this I have created an Excel template, cut the data up into manageable chunks (30,000*8) with array subset and then pasted the data into the right columns. Now all this is working fine 🙂
However I only see two ways of opening the data "Read from spreadsheet file.vi" and "Read DBL spreadsheet file". Now if I use the first it always converts the data into 0.00x and i need 0.0000x at least so I get whole swathes of zeros with the occasional 0.001! Even changing the "format" to "%.7f" or "%.7g" makes no difference? Do I have to dig into the code? Somewhere inside it it must have a constant set to "%3.f"??
Using the second vi I get a whole different problem, it doesn't seem to round the data but it can't recognize the correct tab points. I.e the date stamp is spread over the first 8 or so columns. is there a specific tab limiter I need to put in to the "write waveform to spreadsheet file" I tried "\t" to no avail!
Jon
Message 22 of 24
(1,424 Views)
Aha sorted it 😄 In case anyone cares... I needed to read the file as a string not as a double, and to remover the extra tab condition (\t) which I had wired into the "write waveform to spreadsheet.vi" which was confusing it apparently!
Happy days!
Jon
Message 23 of 24
(1,411 Views)
Hi Jon,
I'm interested! Glad you got that working effectively. Sorry you beat me to the reply!
Best wishes
Rob L
UK & Ireland
Message 24 of 24
(1,400 Views)
