exporting a list of a full VIs and their path in a hierarchy
I would like to know if there is a way to display a full list of VIs hierarchy with their path along and to export that window to a standard jpeg or another data base.
The current dispay of Labview 2009 has two forms of charts and not list.
I thought to use that feature for documentation purpose as well.
Message 1 of 9
(3,695 Views)
Hi pini,
use property nodes to get a list of all VIs (and their hierarchy) in memory...
Message 2 of 9
(3,688 Views)
@pini wrote:
[..]The current dispay of Labview 2009 has two forms of charts and not list.[..]
Are you referring to the "VI Hierarchy Window"?
I have a hard time to see a general purpose of "a list" regarding call hierarchy display. The reason:
  • How should it look like if a subVI is called by more than one caller?
  • How is the list structured (tree, flat, ...)?
Norbert
Norbert
Expert: Geometry
Message 3 of 9
(3,671 Views)
Thank you!
Message 4 of 9
(3,667 Views)
Here you are
Gernot Hanel
IONICON Analytik Gesellschaft m.b.H.
Message 5 of 9
(3,255 Views)
Hey Gernot,
Did you have a question related to this document? If you do, it would be better to create a new post, as this thread is a bit old.
Claire C.
AppSW Staff Product Support Engineer
CLD|CTD
Message 6 of 9
(3,246 Views)
Sorry this was a huge mistake and should not be a reply to this message. It was planed to send it to a different place.
Thank you for the advice.
Best regards
Gernot Hanel
Message 7 of 9
(3,243 Views)
You can ask the moderator to remove the post if it contains sensitive information.
Bill
CLD
(Mid-Level minion.)
Message 8 of 9
(3,237 Views)
Thank you for the information but there is nothing sensitive in it
Gernot Hanel
Message 9 of 9
(3,228 Views)
