exporting data generated in NI ELVISmx to excel spreadsheet
Hello, all!
I have generated a signal using NI ELVISmx and used it in a circuit. I have also collected the circuit output using the myDAQ and can view it in the ELVISmx oscilloscope. Is there any way I can export the data to an excel spreadsheet? Thank you!
(2,420 Views)
Attach your code (the VIs, not pictures).  This tells us a lot more information, and lets us "test" parts of your code.  What "edition" of LabVIEW are you using?  Does it include the Report Generation Toolkit (which lets you write data into .xlsx files)?
Bob Schor
(2,379 Views)
