exporting data to exiesting excel shhet
Hi All....
How do i export data to existing excel sheet?
ie,i want to export to the same sheet whenever the program executes.
if the sheet already contains data,then have to overwrite....
Thanks in advance
Message 1 of 19
(5,215 Views)
There is a shipping example using AcxtiveX (C:\Program Files\National Instruments\LabVIEW 8.6\examples\comm\ExcelExamples.llb) that shows how to write to a specific range of cells in Excel. That should solve completely your problem.
Chilly Charly    (aka CC)
Message 2 of 19
(5,208 Views)
Hi...
Thank you for the reply.Now i camn open an existing file.But fail to write data to that....
I want to display the 2D array .But i cudnt find a way...I cudnt wire the two...
as one ois deeling with work sheet and the othere reference...
Pls help me on this
Thanks again...
Am just sending my ciode extract...
Message 3 of 19
(5,188 Views)
From your attached jpg, I can see you are using the Excel report toolkit.
Why don't you simply create a new report and use the same file name to overwrite the data ?
Message 4 of 19
(5,174 Views)
Thank u so much for the repy..can u pls send sample code if u hev some wth u..am using LV 8.0
Message 5 of 19
(5,127 Views)
May be you could have a look in your own example folder ? Try C:\Program Files\National Instruments\LabVIEW 8\examples\comm\ExcelExamples.llb
Message 6 of 19
(5,118 Views)
Thanks again...i gone thru the examples b4 ....But cudnt find a solution to my problem...
Thanks for help
Message 7 of 19
(5,112 Views)
I can't see where you are stuck. May be you should be more specific whith your question : prepare a set of test data that you would like to write to an existing Excel sheet. Post both the data and the sheet. Post also a prototype, as simple as possible of your code.
Message 8 of 19
(5,105 Views)
Thank u so much for the timely help.
I have a module in our software to display data and then to export to excel.
When viewed in labview window...all coming good...But when exporting to excel some date getting changed...
dates like13/12/2008,11/11/2008...displaying correctly in excel...But dates like 03/02/2008 getting changed as 02/03/2008...
I thought of fixing in one of the two ways...1 way is to use set column format as dd/mm/yyyy using excel set cell format.vi..That code snap i am attaching herewith.
The second was...to keep an excelsheet whose first field is in the format dd/mm/yyyy and always display the data in that sheet..that code i have posted earlier to u and we were discussing on that issue...
The two methods fails for me...Whatever method is ok..
Pls help me in finding a work around for this issue.
Thanka again...
Message 9 of 19
(5,071 Views)
As I asked before, post a working example exibiting your problem (ie a VI writing a set of data that don't display correctly in Excel). Otherwise we wont be able to reproduce your problem and help to solve it.
In a previous post, the date problem was solved by adjusting the cell format to string before writing the data, then reverting to date after. Did you try that solution ?
Message 10 of 19
(5,061 Views)
