external trigger using allen bradley Micro Logix 1000
I am new at using Labview, I have 2012 Labview Full, using cDAQ-9174, with moduals 9205, 9213, 9227. I want to use Allen Bradley MicroLogix 1000 as an external trigger when I cycle units on and off and data log AAC, Temps, VDC and ADC readings 1 second prior to the 5 minutes on and shut down 1 second after the 5 minutes on. Can I pause the data logging bewteen ON cycles and resume every on cycle and not have to open up a new log everytime? Is there a block diagram template I can use to get started? Oh the test will run 5 days 24hrs.
Raul
(2,753 Views)
Hi DustDevil,
Please refer to this example:
https://decibel.ni.com/content/docs/DOC-16359
You can use your external trigger as the control to pause the logging.
Carmen C.
Application Engineer
National Instruments.
(2,740 Views)
Hello Carmen,
Thank you for the information.
Dustdevil
(2,723 Views)
