externally trigger hr2000+ spectrometer with dg535 delay generator
Hello all,
I have three Ocean Optics HR2000+ spectrometers, an Ultra 100 laser, and a Stanford Research Systems DG535 delay generator. I'm using the delay generator to trigger the laser, shortly followed by the 3 spectrometers (all 3 simultaneously).
I've managed to get this procedure working in SpectraSuite and tried to replicate it in LabView using the HR2000+ LabView drivers. The spectrometers have individually worked in normal and external trigger mode in LabView, but as soon as I try to fire and sync all 3 spectrometers using the delay generator, LabView staggers their waveform acquisitions to happen one at a time. This defeats the purpose of the delay generator.
I tried using a flat sequence structure to make sure the integration times and triggering modes have executed before the waveform acquisitions begin with no success.
The attachment shows my code before I had a flat sequence frame between the trigger and waveform acquisition functions.
The delay generator has been controlled both manually and through LabView as well. I'm using a Win 7 machine.
Thank you for any help!
Sincerely,
Mike
Message 1 of 8
(4,353 Views)
Initially I suspected this was a problem with the USB ports, but the spectrometer synchornization works in SpectraSuite. I'm hoping the same is the case with LabView..will I need to buy extra hardware? In my Google searches I keep bumping into DAQ devices to make this all work. There must be some other software based way without introducing another piece of hardware into the system.
Message 2 of 8
(4,346 Views)
Hi Michael,
What is the example code(s) from the HR2000+ LabVIEW drivers that you are basing from to come up with the VI you have implemented? I think the problem here is to come up with a VI that acquires continuously multiple channels simultaneously. We are achieving everything but the simultaneous part, right?
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
Message 3 of 8
(4,326 Views)
Hi Daniel,
Attached is the driver I used.
My code looks more like the Acquire Multiple Waveform VI under the Example folder.
Are you suggesting I do something similar to the Acquire Continuous Waveform VI?
Everything works up until the simultaneous part, and it also works one spectrometer at a time.
Thanks!
--Mike
Message 4 of 8
(4,324 Views)
This is the stripped down version of the code I'm using.
This one has a while loop in there, but previously I've had time sequence frames around the trigger and a separate one around read_spectra -> waveform parts.
Message 5 of 8
(4,321 Views)
I was wondering if you got this to work properly. I am working on something similar but I am very new to LabView and not sure how to code it. I would appreciate if you could show what sub Vi you used to get the standford dg535 trigger to work.
Message 6 of 8
(3,800 Views)
This is a pretty old thread. I recommend making a new thread so that it has more exposure and is more likely to get a reply.
Shreyas
Message 7 of 8
(3,793 Views)
Hi Daniel,
I am new to labview.
I am trying to implement a similar task, but with 16 HR-4000 spectrometers, and have come up with a similar vi like Michael's (specs_with_trig.vi) by following examples from the ocean Optics' drivers.
The problem is synchronization, I observe that labview activates and sets each spectrometer in turn, before reaching the while loop. After reaching the while loop all the executions happen in turn. Is there a way to make all of them work together in sync. Has there been some solution to this in the past few years.
-Hari
Message 8 of 8
(3,698 Views)
