extra bytes when write to binary file
I get 4 extra bytes when i try to write to binary file in LV 8.2. How can i not include those 4 bytes in the file.
Ed
(3,355 Views)
There's a flag on the Vi that can be set to prevent the length of array or string to be prepended to the data.
André (CLA, CLED)
(3,351 Views)
I can't look at your code because I don't have LabVIEW here, but both the flatten to string and the write to binary file functions have a "prepend array size" boolean input. As the name says it will add the array size (I32 I guess) to the string. If you deselect that, the size should be correct.
EDIT: hmm, André was quicker...
Message Edited by dan_u on 11-12-2007 06:07 PM
(3,348 Views)
Thanks, that is work.
(3,336 Views)
