extra points on graph
Hello
I have a set of data in two colums
Col 1 = date in M/D/Y format
Col 2 = Data (numbers)
I have the XY graph plotting the data according to the date but as I zoom in and out I notice weekend dates are showing up
the data was only taken during the week.
When I review the array that is sent to the time conversion FOR LOOP it does not show any weekend dates.
Are these dates showing up because of the way the XY Graph handles the different Zoom levels as the date is fed into it in the UTC format
I would really like to be able to:
1. Get rid of the extra dates
2.  Be able to have booleans or runtime shortcut menu toggle different zoom levels such as daily, weekly, monthly, etc,,,,,
Any suggesstions would be appreciated
Tim C.
1:30 Seconds ARRRGHHH!!!! I want my popcorn NOW! Isn't there anything faster than a microwave!
(3,386 Views)
Added a control to see if a sunday date was being generated via the UTC function
And there does appear to be weekend dates being generated
Does anyone know why these weekend dates would be generated from a UTC funtion if a weekend date is never fed to it?
Tim C.
(3,382 Views)
I forgot to attach the code I have been woking with...
I use the open text file to work with the date as a string and I use the read spreadsheet file so I can work with data as nubers
Thanks again
Tim C.
(3,380 Views)
I worked on the code some more to get the basis for zooming the XY graph
I also toggled the Date/Time to second function UTC parameter and noticed that I could get the weekend dates in seconds to
no be included in the array sent to the XY graph but the weekend days still show up on the X axis.
Is the anyway to make the weekend dates not show up on the x axis?
Tim C.
(3,376 Views)
You mean skip these dates?
like:
Mon   Tues    Wed   Thurs   Frid   Mon
I don't think so.
What you could do is remove the text formatting from the axis. Subtract two days for evere week from the data (week 1 no subtraction, week 2 2 days, week 3 4 days and so on) and create a picture (transparant background, with the days in them and place these over the axis) positioning this might be difficult but it should be possible. You even can create the dates in them.
succes,
Ton
My LabVIEW Ideas
(3,373 Views)
