extract and display array elements
is there anyway to display every element from a 1-D array in separate indicators? For instance, if i have a 1-D array with n number of rows, how can I index each element and display each element in separate indicators? Also, I would like to programmatically display those indicators based on the array size, that is, if i have 10 rows, i need 10 different indicators with each indicator displaying the elements corresponding to the index. Please see attachment.
(3,108 Views)
Like this?
You'll have to set the number of elements in the cluster to the maximum array size expected.
I used a cluster just to easily get a list of controls. Otherwise, make an array of individual control references.
LabVIEW, C'est LabVIEW
(3,108 Views)
Thank you so much Jean. That really helped.
(3,108 Views)
