extract and index every n elements of an array
i    x                                          x
0  10                to                   0  10
1  20                                      3  40
2  30                                      6  55
3  40                                      9  70
4  45
5  50
6  55
7  60
8  65
9  70
I am trying build a 2D array with the extracted values: one array being the index, and the other is the value of that index shown above.
The goal is to extract every n elements (n=3 in this example shown above) out of an array and index the elements and put them in a 2D array. I used the "decimate.vi", and it can extract the element but unable to provide me the index of that element , so does any one know a more efficient solution to program this?
Please help
Thank you
(4,440 Views)
Here is how I would do it.
21115i3F6B167D0E2C5FA8
Tim
GHSP
(4,427 Views)
Thanks for the help. Aeastet, can you please save as the VI in labview 2009, as I am using labview 2009, or show the true case structure screen shot, as I cannot see the true case structure program base on the posted screen shot.
Thank you
(4,409 Views)
Here you go
21143i611014E215FEC2F7
Tim
GHSP
(4,403 Views)
I am a 'decimator' myself.  Only with arrays, not in the Roman sense.
(4,391 Views)
Your problem is not very well defined, so I make some assumptions.
I assume the input array is 1D, and the index is implicit. Here's my solution:
It would be trivial to adapt to a version with a 2D array input. try it! 🙂
(4,371 Views)
