extract boolean value from variant
Hello, Sorry for my incomplete explanation, but if you are given that specific stop button in an exam, can you modify it to your suggested solution and not lose any points?.
Message 11 of 16
(1,681 Views)
Hello, how would you typically go about resetting the button to its default value?
Message 12 of 16
(1,677 Views)
Command buttons should be latched.  I am not sure about losing points for changing the mechanical action (I would guess that you would), but you definately would lose points for the local variable or property node for resetting it.
Message 13 of 16
(1,673 Views)
Hello, thanks for your input.  I see that in order to overcome then the local variable, I would have to use the shift register.  How then would you go about resetting the button without using the property node value?
Message 14 of 16
(1,669 Views)
A latch action button resets itself. Just place thee terminal in the dataflow.
Message 15 of 16
(1,650 Views)
By doing one of the options I gave you here.  By having the button set to "Latch When Released" and putting the terminal in the event case, the button will "reset" when the event is handled since that is where the terminal is read, causing the unlatching to happen.
Message 16 of 16
(1,631 Views)
