extract cluster element names and values automatically
Dear Labview forum,
I would like to extract cluster element names and values automatically without prior knowledge of the cluster element size or contents.
I am able to extract the names but have some trouble with the values.  (see attached VI)
I wish to write each the cluster element name and value in a string, and then write the string to a new line in a file.
Jamie
Using Labview version 8.0
(8,227 Views)
This can become arbitrarily complex, because a cluster can contain many types of data, even other clusters, arrays, typedefs, etc. So getting a "value" of an element is not as easy as you might think. There is a reason you get a variant. 😉
If all cluster elements are simple numerics you can use "variant to data" with the correct type. The attached shows a few possibilities. Modify as needed.
(8,216 Views)
It will be better that ur question is a little bit clear.
I think ur query is regarding how to get the cluster element values?
The vi below will be helpful for u
Padmavathi B  (GroupMember)
(8,215 Views)
Parsing all the different data types to be able to write it to a file is a lot of work.
Luckily, the work has already been done - You can go to the OpenG site and download the Variant Configuration VIs which allow saving and loading clusters to text files. See here for an example.
___________________
Try to take over the world!
(8,213 Views)
Another example using the OpenG toolkit is found here
Ton
My LabVIEW Ideas
(8,207 Views)
Hi all,
altenbach's solution was what I was looking for.  The openG options I haven't yet explored.
Thanks for everyones' help.
Jamie
(8,197 Views)
