extract data from graph
hi mike,
thanx for the VI. that is what i needed.
however, i cannot use a external button (the push button) to initiate the case structure.
i did to do everything in the block diagram.
is there any other method that i can use.
thanx alot!
Message 11 of 13
(1,143 Views)
jylok1 wrote:
hi mike,
thanx alot!
Hi jylok1,
i don´t understand it. What do you mean with "to initialize the case structure"?  The can have one of two states. Connect the button to your case structure and build it, that the false case do what you need if the button is false. The button value should also be false. How would you decide when to change? I thought you need a button.
 Explain what you need please, soory i lost you!
 Mike
Message 12 of 13
(1,131 Views)
hi mike,
sorry for making u confuse.
thanx alot for all the suggestion.
have finally got it.
Message 13 of 13
(1,111 Views)
