extract datas from XY- graph
hi,
         how to extract the graph data in XY - graph using cursor's, i checked with property nodes cursor index returns always zero  while i moving the cursor..
i was already done with same coding with labview 7.1, was working fine...
i am new with labview 8.5. i think that i need to do other ways...
suggest me how to do?
thanks,
balaji dp
Balaji DP
Message 1 of 8
(3,844 Views)
Hi balaji dp,
what do you want to do? Can you explain a little bit more?
Mike
Message 2 of 8
(3,842 Views)
i have an waveform in XY - graph, i need to extract the waveform , where i cursor's are placed on....
Balaji DP
Message 3 of 8
(3,840 Views)
Message 4 of 8
(3,831 Views)
here i attached vi, this is for labview 7.1
Balaji DP
Message 5 of 8
(3,829 Views)
Hi balaji_dp…,
your example works great for me with lv8.5.
Mike
Message Edited by MikeS81 on 06-06-2008 08:40 AM
Message 6 of 8
(3,825 Views)
in 7.1 can simply write the code like this....
is this possible like same type of coding in 8.5?
i seen that link which u reply on ..but thats some what big coding?
balaji
Balaji DP
Message 7 of 8
(3,820 Views)
Hi balaji_dp…,
yes, you can write this code in 8.5 in the same way. All properties are still available.
Mike
Message Edited by MikeS81 on 06-06-2008 08:57 AM
Message 8 of 8
(3,814 Views)
