extract iteration number from event structure
Is there a way to extract the number of times a labview routine goes into an event structure?
hiNi.
(2,654 Views)
Accepted by topic author hiNI
I am not sure what you mean by a routine going into an event structure.
If you have the event structure in a while loop as is usual, then the value of the iteration terminal will tell you how many times the structure has executed.  If you want the count for a particular case, use a shift register with an increment function in the case of interest and the others wired straight through.
Lynn
(2,643 Views)
THANK YOU!
(2,628 Views)
