extract non zero indices from a 1D array
Hi all,
I want to extract non zero indices from a 1d array. Can anybody suggest me how to go about it.
KM
(5,102 Views)
Hi kamasani,
can you explain the term "non-zero indices"?
Are you talking about array elements? Do you need non-zero elements?
Use a FOR loop to autoindex your array and a conditional output tunnel:
(5,096 Views)
I have a 1d array of  floating point numbers. I need to extract the index numbers of  non zero floating point numbers.
KM
(5,076 Views)
Hi kamasani,
you want to know the indeces of non-zero elements?
Take my snippet above and do that little change that is needed to get those indices! 🙂
(5,072 Views)
Hi GerdW,
Thanks for your reply, i am using LV2011,i Undestand what you meant. i doubt conditional auto indexing feature is not available in 2011, i need a little more help.
KM
(5,057 Views)
Accepted by topic author KevinKM
Hi kamasani,
so you need a shift register, a BuildArray node and a case structure.
I'm pretty sure you will find examples for such tasks in the forum…
(5,054 Views)
Hi GerdW,
Thanks for your time, I found the solution finally.
KM
(5,049 Views)
