extract numbers one by one from a 1-d array
Funny thing with lab-VIEW.  Something that should be so easy seems so hard until you see how!
All I want to do is extract each number one by one from a 1-d array in a loop so I can enter them into a pt by pt routine (specifically Savinsky-Golay ptBypt.vi.
This is so I can process data offline using the Savinsky Golay algorithm.
(2,888 Views)
I never got to using the pt by pt functions, but as for extracting element by element from a 1d array I would suggest you use a for loop, wire the array to it, right-click on the tunnel and select "enable indexing." By default it should already be enabled.
(2,886 Views)
Thanks Aart-Jan
Will display the code when complete
(2,879 Views)
Hi
is this what  you are looking for ?
Just replace sin wave pt by pt vi with appropiate vi
and modify parameters to suit.
chow
xseadog
(2,879 Views)
Building the array and then indexing it is not necessary.  The enable indexing terminal is all that is needed.
Message Edited by tbob on 09-07-2005 10:41 AM
- tbob
Inventor of the WORM Global
(2,859 Views)
