extract y value from graph at any given time
I have a graph with a pre-plotted curve generated from a standard set of results. I need to extract the y value of the curve at any given point. My y value is pressure and my x value is stroke(hydraulic cylinder movement in mm). So for example at 10mm(x value) I need to extract the pressure(y value). Is there a property node I could use for this? any help would be much appreciated.
(3,002 Views)
Hi Alan,
instead of reading values from the graph you may use the interpolation functions from the array palette to do interpolation on the plotted values directly...
(2,995 Views)
Many thanks for this, I will give it a go I have not used this function before so its going to be fun!!
(2,992 Views)
Can you please example for this question.
Hari
(2,653 Views)
