extracting VI documentation property
Hi
How can I extract a sub Vi's documentation property as it does not seem possible to creat a property node for an object as high as a VI
Mike
(3,305 Views)
Hi Mike,
what do you mean. Do you search a property which can read the vi documentation? If yes see the attachment. You can change the class with right click on the property node and select "select class".
Hope it helps
Mike
Message Edited by MikeS81 on 02-13-2008 06:23 AM
(3,300 Views)
Search for VI Server. With Open VI Reference, you can get references to VI's
(and read their documentation).
Wiebe.
(3,293 Views)
Thanks guys both examples work well.
Regards
Mike
(3,274 Views)
