extracting a person from a image
how can i extract a person from its background in an image. Actually i want to calculate the area occupied by that person.
Message 1 of 12
(3,980 Views)
Is this an image analysis application? If so use blob analysis. You will need to create a blob out of the person's image. Determine the size of a single pixel. Then count the number of pixels in the blob.  Mulitiply.
PaulG.
Retired
Message 2 of 12
(3,951 Views)
In order to create this blob in the first place, which is called "segmentation", you could use k-means as shown here in Kl3m3ns Blog:
https://decibel.ni.com/content/blogs/kl3m3n/2014/10/15/color-image-segmentation-based-on-k-means-cl...
Message 3 of 12
(3,935 Views)
Unfortunately what he really needs here is not just Blob Analysis, it's Bob Analysis.  Measuring the area is easy with NI Image tools assuming there's a size reference.  The hard part here is going to be the A.I. that determines that a particular set of pixels form the shape of a human being.  Tricky even with a brute force approach where you have a huge library or "human-like" image data to compare to.
This topic probably does belong in the Imaging forum but either way the OP has to provide a lot more detail about his application if he expects any useful help on the subject.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 4 of 12
(3,916 Views)
nice!
Message 5 of 12
(3,879 Views)
Hi
Is there any way i can find the area of the white pixels alone in my grayscale image?
thankyou
Message 6 of 12
(3,665 Views)
Hi niveraja,
yes: count them!
(You count all WHITE pixels and divide by the number of all pixels to get the percentage of WHITE in your image…)
Message 7 of 12
(3,658 Views)
Hi
Yeah but how do I count in labview? I tried histogram but still can't figure out how to get the pixel count from the graph.
Thankyou
Message 8 of 12
(3,647 Views)
Hi niveraja,
why don't you attach a VI with an example image and your histogram approach?
It's a rather good idea to use a histogram for that purpose…
Message 9 of 12
(3,642 Views)
Hi
I have attached a thresholded image with the simple histogram VI I tried. Please help me get the white pixel count for this image.
Thankyou
Message 10 of 12
(3,622 Views)
