extracting array of labels in a cluster
How can I extract an array of strings, containing the label of objects in a cluster?
LV 8.6 on Windoze XP
Message 1 of 14
(9,957 Views)
Use a reference to the cluster and a property node. If the cluster can contain other clusters and you want the names of the objects in those subclusters, things can get messy fairly quickly, but it can be done. Open G may have some tools for this, but I am not sure.
Lynn
Message 2 of 14
(9,952 Views)
I I hear what you're saying.  The problem is I haven't found where the labels if the children objects are hiding.
Can you please tell me where to look and how?
Message 3 of 14
(9,932 Views)
Here is a VI I put together to explore access to all the controls on a panel. I need to change the captions (not the labels) programmatically for language localizations. Both language versions of each caption may be stored as diagram constants, or, more flexibly, in a configuration file. This VI is not documented and has a lot of rough edges as I did not plan for anyone but me to use it and only as a learning tool. LV8.20.
Lynn
Message 4 of 14
(9,920 Views)
Assuming you're using LabVIEW 8.2, try this VI, which makes use of the Variant VIs introduced in LabVIEW 8.2 (OpenG provides a similar VI).  Convert your cluster to a variant and then wire it into this VI.  The outputs are:
1) an array of strings containing the names of all the child clusters
2) an array of integers, which are indices of the parents of each child cluster
3) an array of strings containing the names of all final child elements
4) an array of integers, which are the indices of the parents of each final element
5) an array of enumerations corresponding to the type of each final element
I use this in a number of situations, including a VI that can populate a tree control to match a cluster, which I'd be happy to post too if that's of use to anyone.
Message 5 of 14
(9,913 Views)
Hello nathand,
is it possible to do the reverse, that is to say from a
nested variant tree, cast it into a cluster an bundle
it into another existing cluster ?
David Koch
Message 6 of 14
(9,100 Views)
I don't think there's a single VI that does what you want, but the OpenG Variant tools might provide enough help to make it possible to build one. There are tools there for building a cluster from a Variant, which basically build up a flattened string representation of the cluster which you can then unflatten.
Message 7 of 14
(9,077 Views)
Hello Labview Super Sayian, could you please check my
proposed solution here :
https://forums.ni.com/t5/NI-TestStand/Enqueue-Teststand-cluster-to-Labview-return-a-cluster-by/m-p/3...
It is still a WIP though...
David Koch
Message 8 of 14
(9,004 Views)
I'd like to see an example of what you are thinking, but I think my XNode posted here could be a start to making this work.
Message 9 of 14
(8,911 Views)
Hello Hooovahh, thanks for the feedback.
Here's my current progress, I'm blocked
though.
The idea is to recreate a nested variant
from any input (cluster elements or from
a PropertyTree incoming from Teststand)
and cast it using 'VariantToData'.
Please refeer to the related topics :
http://forums.ni.com/t5/NI-TestStand/Enqueue-Teststand-cluster-to-Labview-return-a-cluster-by/m-p/30...
http://forums.ni.com/t5/NI-TestStand/How-to-use-LabView-s-created-notifiers-in-Teststand/td-p/305986...
http://forums.ni.com/t5/LabVIEW/Convert-Labview-cluster-name-to-Teststand-container-name/m-p/3067857
David Koch
Message 10 of 14
(8,884 Views)
