extracting data from access and plotting onto graph
hihi,currently I'm trying to extract specific column data(voltage) so that I can plot the whole column information onto graph vs time straightaway,to review the history.
Currently using database API ,using the commands "move to Can anyone enlighten me on it?Thanks alot!=)
(2,876 Views)
Is this the same as your question here? What is 'move to' and what does it have to do with your query? What is the problem with retrieving a column? Do you simply need to convert from a variant or a string?
(2,866 Views)
Simple example are given in the Example Finder for fetching the database,
if you have the database connectivity toolkit.
Shrek
(2,863 Views)
