extracting info from an array
@thomasd6 wrote:
Hello Bill,
also i do not want to force any of the values into range and how will boolean pass any value i want to keep into another array please read carefully as to what i am trying to do
Kind Regards
Thomas
One way you can use it is the array of booleans will have indices that corrrespond to your data.  Base your selection on the indices that are true.  See, I *did* read your post carefully.
On another note, anyone know of a better way to do this?  It sounds rather clunky to me, but it would work...
Bill
CLD
(Mid-Level minion.)
Message 11 of 17
(1,308 Views)
You only need to ask.
The False case is a pass through of the data on the shift register.   You were going on the right path.  The NaN default value is a better choice (Won't even show on a graph) and 0 is an "almost good" value.   IR&C works fine on arrays.
Message 12 of 17
(1,297 Views)
Thanks all,
I managed to figure with it out i used the range and a select box that either filled the array with a zero or passed the vaule into the array.
thanks am going to try the way shown below thanks for the help!!
Kind Regards
Thoms
Message 13 of 17
(1,279 Views)
Hi Thoms,
there's a Ramp function to calculate your frequency array...
Message 14 of 17
(1,275 Views)
ok !! where could i find that please
Message 15 of 17
(1,270 Views)
Hi Thoms,
either press Ctrl-Space and search for "Ramp"
or
look into the signal generation functions palette
Message 16 of 17
(1,269 Views)
@GerdW wrote:
Hi Thoms,
I have to admit - I wouldn't have thought about using the ramp function, but if you think about it, a progression of frequencies is a ramp!!!  One more thing to add to my playbook.  😉
Bill
CLD
(Mid-Level minion.)
Message 17 of 17
(1,251 Views)
