extracting numbers from a string
Hi ,
I am trying to find a way to extract all possible numbers from a string ;
for instance the string :
win2000 john 6.25e-3 12.34 wtk75a -17
would give me the results in an array of numbers:
2000.00000
0.00625
12.34000
75.00000
-17.00000
In LabVIEW6.1 there is an example doing so; only the problem lies in the
scientific notation number:
the example sees this part of the string as two seperate numbers: 6.25
and -4 .
Ofcourse I want this VI to see this part of the string as one single number
(0.00625) .
Anyone help will be appreciated ,
René Ramekers
The Netherlands
(4,525 Views)
Try using Fract/exp string to number.
It will do the job
Regards
Dev
(4,515 Views)
Sorry Rene, the attached Vi was in LabVIEW 7.1.
So, u might not be able to open it.
Nevertheless you will find this function 'Fract/Exp String To Number'., in functions palette -> string-> string/number conversion on LabVIEW 6.1 too, so it should not be a problem.
Regards
Dev
(4,512 Views)
Devchander is right on the money but I think you will need a little bit more to parse the string.
This is very similiar to the Extract Numbers.vi example that ships. The only difference is the number format that is extracted for the string using Match Patten.  The Match Pattern returns -1 when it can't any more matches where as Fract/Exp String To Number returns 0 which could be ambiguous.
Might not be bomb proof but it worked for the string you posted.
cheers
David
Message Edited by David Crawford on 11-25-2005 06:37 AM
(4,506 Views)
Thanks devchander & David ,
it works perfectly ,
René
"David Crawford" <x@no.email> wrote in message
news:1132922439537-292746@exchange.ni.com...
only difference is the number format that is&nbsp;extracted for the string
using Match Patten.&nbsp; The Match Pattern returns -1 when it can't any
ambiguous.
> <img
src="http://forums.ni.com/attachments/ni/170/153677/1/Extract%20Numbers.jpg"
> cheers
> David
> Extract Numbers.jpg:
> http://forums.ni.com/attachments/ni/170/153677/1/Extract Numbers.jpg
(4,481 Views)
