extracting particular number of columns from a text file and writing in another
Hi
I want to extract  few coulmns from a text file and write it as it is in another text file. I added "space" as delimiter. The vi I created is working on smple text file with equal number of spaces and digits in a column. But the problem which i am facing is due to unequal number of spaces between two columns.
I thought of copying my data in excel and then extract required columns from there but I am not getting how to do that and will it work or not.
I am attaching the vi of my work so far and the text file also.
Thanks in advance..
rchkrishna
(3,026 Views)
Simple solution: replace all occurances of duplicate space chars by a single space. After you have done so you convert your string to an array...
(It's a bad idea to use a variable amount of delimiters between values in a delimiter-based text file format anyway!)
(2,999 Views)
I tried that also but it is making the data very clumsy and still columns are not correctly separable.
(2,993 Views)
