face recognition using labview
I, am into my final year project. I am  doing face recognition using labview. I want to know how to compare image using labview. it would be  great if someone helped , as it is proving to be a major obstacle in my way
(13,492 Views)
Hi Sibom,
You may want to check Vision Development Module for LabVIEW. You can check them out at
https://www.ni.com/en/shop/data-acquisition-and-control/add-ons-for-data-acquisition-and-control/wha...
In this forum, people try to answer questions but we would need you to do your part of the work and what you have done to resolve the issue that you face. We can't help you if you just wanted answer without even trying.
Regards
- Meadow -
LabVIEW 7.0 - 2011, Vision, RT, FPGA
TestStand 3.0 - 4.5
(13,488 Views)
You Might also look into the examples provided with NI Vision. There's one pretty good example for pattern recognition that might make your project obsolete... I haven't looked into it to deeply though.
You can find the example in your NI direction:
National Instruments\LabVIEW 2010\examples\Vision\2. Functions\Geometric Matching
Remember Cunningham's Law
(13,478 Views)
I have succesfully matched the front view of a face . But the template matching considers only the position of the image in template . If the image is a little angled or tilted than the template's image it gives a score of zero. Also if u can please tell me if a side view can be used to reconstruct or recognise the front view template of an image , eg. a face.
(13,427 Views)
Hi Sibom,
There are various face recognizing algorithms available. If your purpose is simple face recognition, then the simplest method would be to segment the image using a line, and to perform the recognition for every tilt of the image.Tthus when the line traces 180 degrees, all possible positions would have been verified.
If you like a more holistic approach you can have a look at the trace transform model and the active appearance model, which are used in the industry.
These models can be studied at :
 http://www.face-rec.org/algorithms/#Image
Siva
(13,389 Views)
good afternoon,
i am doing my project in eye detection technology.
i am new to labview software.
i have been trying to locate eye region but i am not getting perfect results for that.
i am using pattern matching in vision assisstanat.
please guide me.
i need your help very badly.
(12,772 Views)
