factors affecting the speed of serial transmission using labview
We are facing this problem.. We use pc com port for serial transmission (9600 baud) to read from our serial device we write 2 characters( 10 bits each) and we get back 23 bytes from the interface).. Our speed is limited to 235msec otherwise the vi wouldn't operate correctly.. We don't know why is this i think we can reach at least 8 times faster can't we?
(2,720 Views)
Yma,
Is the response-time of the serial device documented?
Typical small serial devices lack the necessary processing-power.
And what is actually going wrong when you write at a higher rate? Have you checked for error-codes coming from the serial read/write vi's?
Maybe this was helpful,
Patrick de Boevere
(2,720 Views)
Are you doing a read with time out?
Is PC doing anything else at the time?
Are you reading correct number of gytes?
FYI
Your 40 ms target loop time will not be deterministic in Windows.
Ben
(2,720 Views)
