failed to discover chassis 9075 - I can not see my NI 9234; NI 9227; NI 9263
Unless you've installed software between the time you posted the ni support zip and your most recent post, it doesn't matter WHAT you've installed.  It's the wrong version.  The link I sent you in the last post is the ONLY version of the drivers compatible with LV 2015 SP1.
Until you fix that, the rest of the troubleshooting is a waste of everyone's (yours included) time.
Message 11 of 15
(2,382 Views)
Accepted by topic author Ihab
Hello Natasfw
Thanks for your reply
I downloaded cRIO 15.5
Installed it.
Here is the screnshot , but still can not see my C-series modules - any tip?
Message 12 of 15
(2,356 Views)
What software have you installed on the cRIO?
Expand the software tab.
Have you installed the ScanEngine ?
Message 13 of 15
(2,334 Views)
As mentioned before, you will not be able to see C series modules in MAX if they are in a cRIO chassis. You can read more about it here.
If proper drivers are installed, this procedure work and you should be able to use your modules.
Message 14 of 15
(2,324 Views)
Hello
Here is the software installed
Message 15 of 15
(2,302 Views)
