failure build distribution
Hello
I trie to build a distribution just with the exe. First few times it works well. But now the Installer is requesting for the setup distribution path. The default path is showing as X:\SmartView\SmartView\Installer\Volume but it will find nothing. Where should this path going?
LabVIEW cannot locate some components necessary to build the installer. The components are from the following distribution(s):
Distribution name: Setup
Last known distribution path: X:\SmartView\SmartView\Installer\Volume
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_Build.vi >> CDK_Engine_PromptForMissingDist.vi
Loading product deployment information
Adding files to installer
Done adding files
Preparing to build deployment
Copying products from distributions
*** Error: Improper function call or command line argument. (Error code -30)
*** End Error Report
Copying distribution 'National Instruments Gerätetreiber - November 2005' from: F:\ to: C:\Dokumente und Einstellungen\p13076\Desktop\SmartView\Installer\
*** Error: Input data from a source data file
(3,104 Views)
The text in the message box is    //  locate the SETUp distribution. Labview needs to copy a component installed or updatet by the distribution to continue building the installer //
The default path appears as :X:\SmartView\SmartView\Installer\Volume but there will be not a contiue
(3,096 Views)
Hi halo,
There is a similar discussion about what you are asking. I suggest to read the discussion and try the things out, what helped for others:
http://forums.ni.com/ni/board/message?board.id=250&message.id=20872&requireLogin=False
Evrem
(3,082 Views)
