failure if acquisition in a loop with Keithkey2000
I encounter several problems with a K2000 Multimeter, during the acquisition of tensions on 4 different channels with Labview 7. The program uses the VI of the library of the driver of K2000 for Labview 7.The stages are as follows:
1- Initialize
2- Configure DC Volts: PLC = 10
3- Configure Trigger: Source = Bus, Initiate = Continuous, Custom count = 1
4- While loop containing a For loop of 4 iterations selecting the number of the channel by mean of a condition structure which contains:
                           a- Configure Route Single: Close, n° channel
                           b- Action send trigger
                           c- Wait for 1000ms
                           d- Data Read Single
5- Close.
The list of the 4 channels is not an increasing list of consecutive numbers.
Encountered problems:
1- the execution stops after 5/6 measurements at Wait for RQS in spite of the time out of 25000ms.If I remove Wait for SRQ in Data Read Single I do not have this problem any more.
2- the error -211(trigger ignored) appears at the beginning of the execution. If I choose don't reset in Initialize this error does not appear any more.
3- if I apply a filter with Moving Average and 10 Readings, I obtain incoherent measurements and this, whatever are the values of the time delays introduced in Trigger and before Data Read Single.
I read all documentation on the site of Keithley but I did not find a solution. So I need some indications especially for the third problem because I must imperatively filter measurements.
I thank you for the assistance which you could bring to me
Sinou.
(2,819 Views)
Hi
I think that the problem can only be solved by your fabricant. He has developed the driver.
Kamal
NIF
(2,808 Views)
