failure: objheap.cpp , line480 when trying to build executable in labview 6.1
I have a vi that runs and works fine. I am trying to build an executable file using "Build Application or Shared Library". When the Build starts I get an error towards the middle saying "failure: objheap.cpp , line480" . I would really appreciate if anyone could give me some insight onto fixing this problem or why this might be happening.
(2,983 Views)
Here is a quick search leading to some threads which discuss the same thing. Please go through it completely and post back what you find. Please mark this post as solution, if your problem is solved.
Mathan
(2,963 Views)
