fast buffer (array manipulation)
I want to make a buffer for displaying graph with limited sample size like a size of history in a chart.
Using Delete From Array.vi, I realize the buffer but slow performance with large array input (upto 2MS/s).
Can you suggest any new routine for fast buffering (simple ring buffer)?
labmaster
(3,909 Views)
Your code makes no sense. Why don't you attach an actual VI instead of an image?
Is this a subVI? How is this used? What does "delete from array" have to do with a history buffer???
What is "large"? 2MS/s is a rate, not a size. (2MS/s for 1 micosecond is pretty small, but 1S/s for a century would be pretty big. ;))
In order to keep performance high, you need to avoid array resizing and unnecessary extra data copies.
We clearly need more information.
(3,878 Views)
Are you truing to program circular buffer?
http://www.youtube.com/watch?v=m9F7iH8-C5k
LV 2011, Win7
(3,854 Views)
I found my solution. It's not related to the buffering.
When I used "Variant to Data" in high speed (2MS/s) acquisition, the performance was very slow then overflow.
labmaster.
(3,841 Views)
