fatal error (graphobj.cpp line 56 ) when opening a vi
I cannot open my vi. Labview reports a fatal error and exits. Any workaround?
Log file:
#Date: Tue, Oct 05, 2004 11:17:20 PM
#OSName: Windows NT
#OSVers: 5.1
#AppName: LabVIEW
#Version: 7.0
#AppKind: FDS
D:\lvworm\src\lvsource\graphobjs.cpp(56) : DAbort:
0x0070644A - LabVIEW GPIBCloseDevOrUnit + 197BA
0x007063EC - LabVIEW GPIBCloseDevOrUnit + 1975C
0x00706384 - LabVIEW GPIBCloseDevOrUnit + 196F4
0x007138B8 - LabVIEW GPIBCloseDevOrUnit + 26C28
0x009854F3 - LabVIEW TDStandardize + 18F93
0x0085D16A - LabVIEW IsDialogControlFromRef + 1A95A
0x0081ABCE - LabVIEW OMGetClassPropListIds + 3E95E
0x008561FA - LabVIEW IsDialogControlFromRef + 139EA
E95E
0x00855FAE - LabVIEW IsDialogControlFromRef + 1379E
0x009DB2DE - LabVIEW TraceToolEnableLogging + 5A9E
0x00A95F4B - LabVIEW SetKeyboardHandlerProc + 827B
0x00A8E0AC - LabVIEW SetKeyboardHandlerProc + 3DC
0x00B84639 - LabVIEW WSendEvent + 229
(4,200 Views)
could you poste your vi, which causes the fatal error.
So I can try to reproduce the error.
Sebastian N.
NI Germany
(4,200 Views)
Hi, I have tried to open with lv7.1. The result is the same error message, but the log file differs....
Regards
Tamas
(4,200 Views)
Dear Tamas,
I have reproduce your problem.
It is the same message, which you get.
Is it possible, that you can create the VI step by step. Save and test.
So you can find which SubVI or Indicator causes the crash. I have found some entries in our database about this Error Message.
However there a several possibilities.
One entry, I have found in the NI knowledgebase, here is the link:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=5065000000080000000FC80000&ECategory=LabVIEW.LabVIEW+General
Best regards.
Sebastian Nowoisky
NI Germany
(4,200 Views)
I am getting the same error. Any update on this?
br,
vishal
(3,847 Views)
Hi Vishal,
Do you receive this error when trying to open your VI in LabVIEW 7.0 or does it occur at a different time with a different version of LabVIEW?  It sounds like some data on a graph somewhere in your VI has become corrupt.  If you want to post a VI that exhibits this behavior, I will take a look at it.
Donovan
(3,825 Views)
(3,822 Views)
