fault in lvalaram.dll generates error event in .NET Runtime 2.0
Hello, a stand alone application written in LV 7.1 generates the error event in the screenshoot. The application contains various timed loop. I have already attemped to remove timed loops but the application suffer. My question is if exist some way to make the application properly working as in the old pc? Actual OS is Windows XP with daqmx 7.4 as well as in the older PC
(2,783 Views)
is your Windows XP at SP3 version?
If not try to update it to SP3 and try to update the LabVIEW version up to 8.5.1. (a patch was introduced to fix this problem).
Regards.
Stefano
(2,738 Views)
