feed results from text file to sectrum analis vi
my
(3,533 Views)
Hello one more time
my problem is->  I got  a results in text file 1. column time 2.  column freaquence. There is only one period i know how to open file and make data in form of cluster of two elements, BUT I can't understand how to convert in dinamic data to feed them fore example here http://forums.ni.com/ni/board/message?board.id=4170&message.id=13641
(3,531 Views)
All you need to do is convert to a waveform data type. This is a cluster with a Y array and t0 and dt values. You only need the Y array and dt.
Message Edited by Dennis Knutson on 08-06-2008 07:46 AM
(3,511 Views)
Thank you, it works like I expected   Smiley Happy
(3,494 Views)
