fetal error: memorymanager.cpp,Line 566
I found error when i run the builded exe.
please see the attachment.
(3,580 Views)
So would I be correct in assuming that this error only occurs with the standalone executable version of your code? Running in the develoment environment, there is no problem, yes?
  • When does the problem occur? At start up or do you have to do someting to cause it?
  • Are you using any external code? DLLs, .NET assemblies, ActiveX, etc?
  • Did this ever work, or did it just start?
  • Can you build other executables without problems?
  • If you install this executable on another PC, do you get the same problem?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,569 Views)
Yes ,Correct-this error only occurs with the standalone executable version of my code
  • when I run the exe, stating only getting this error.
  • Yes,we are using some DLLs and >.net assemblies.
  • last month
  • Yes, I can.
  • Yes, same
(3,516 Views)
Comment out all the calls to non-NI DLLs and .net assemblies and see if the error still occurs.
Mike...
LabVIEW Champion
(3,510 Views)
