fft find frequency
If you want a good introduction to numerical techniques that does not overwhelm you with theory, try the Numerical Recipes series.  I still have a copy of Numerical Recipes in C I bought in grad school many years ago.  Older versions (newer than the one I have Smiley Wink) are available online here.  The older, obsolete versions are fully available to anyone.  The nice thing is that virtually all the algorithms have been implemented natively in LabVIEW, so you don't have to write them yourself, just use them.  Have fun!
Message 11 of 22
(2,129 Views)
Norbert,
Thank you so much! It helps a lot.
John
Message 12 of 22
(2,123 Views)
Thank you.
I tried to isolate the signal using a "low-level" way.
Here is the route :raw data(time domain)——FFT——data(frequency domain)——isolate the signal(set the intensity of the frequencies that i am not interestedin  to zero)——inverse FFT ——to get filtered data(in time domain).
I think my spectrum is better now.
Thanks again!
Message 13 of 22
(2,121 Views)
It's a great news since I will have many homeassignments on labview later this semester.
Thanks a lot.
Message 14 of 22
(2,119 Views)
send me the answer in screen shot. I have labview version 11.0. so it was not supporting. please send me quickly
Message 15 of 22
(2,075 Views)
What screen shot are you talking about? If you need a VI in a different version, use the Version Conversion board you see linked at the top of the page.
Message 16 of 22
(2,051 Views)
The answer which u got. I am in urgency. Pls send me a screen shot of ur block diagram
Message 17 of 22
(2,036 Views)
Message 18 of 22
(2,017 Views)
Here's the last version of the VI that the OP posted saved as 2011 VI. Please note that the OP last wrote on this thread in September and it is unlikely that he is still monitoring it. Please create a new thread with questions relating to your issue.
Jonathan L.
Technical Support Section Manager
Message 19 of 22
(1,991 Views)
sorry dude.
I have to find fft for the time domain of frequency 50 hz,
I don't know that part. Pls help me friends..... My program may be absolutely wrong. But pls help me out.
 My datas are here... Pls note this and get me fft for the time domain
Message 20 of 22
(1,973 Views)
