fglrx module conflicts with labview 8.2
Hi, i need your help.
My graphic card is ATI x1300, and i am using slackware 12.1. This distribution used mesa for graphic driving by default and worked well with labview 8.2.
After i disable the Direct Rendering Manager of linux kernel config and recomiled the kernel(2.6.21.5) and installed ATI officail driver successfully, reboot, labview got the "segmentation fault" error. I confirmed that fglrx module loaded with nothing error.
Then i remove fglrx module and use Mesa instead, reboot, labview works fine.
Any idea to deal with this problem? Or is this a known bug? I want to use fglrx for graphic driving.
Thank you!
Message 1 of 1
(2,599 Views)
