fibonacci 2d array
I was looking through the workshop files here:
https://decibel.ni.com/content/servlet/JiveServlet/download/21043-3-43168/Fibonacci.vi
I'm attempting to modify this file so that it is a 2d array. So if I attempt to add dimension to the one labeled "Fibonacci Sequence" it breaks the program since I beleive
the two aren't matching since there are elements that are in 1D right? So what I want to do is have user input for "n" but also have it show up in the fibonaci sequence first column so that it will be paired up to the fibonacci result in the second column. What ways can I do this? I'm drawing a blank.
I'm stumpted on how to get the userinput to show up into those columns of the 2d array.
Message 1 of 19
(8,827 Views)
hello?
Message 2 of 19
(8,819 Views)
Patience.  It is late on a Sunday night.
Why don't you attach your VI where you attempted to do what you are trying to do?
Message 3 of 19
(8,815 Views)
sorry about that, anyway, I've attached what I wanted to get across, I'm just not sure how to link the n values to the fib numbers
Message 4 of 19
(8,809 Views)
A fibonacci sequence is a 1D object. It is not clear at all what the second dimension should be in whatever you are trying to do.
If you just want a second column containing the index of the element of the fibonacci sequence, that seems trivial to do. What have you tried so far?
Message 5 of 19
(8,807 Views)
OK, we posted at the same time. Simply add a build array before the autoindexing output tunnel and make an array of two element. Wire something derived from the iteration terminal to the other input of "built array".
Message 6 of 19
(8,806 Views)
Another trivial change will ensure that the first 1 also shows. Did you find how?
(Officially, the sequence should start as 0,1,1,2,3,....  there needs to be a zero at the beginning.)
Your output needs to look as follows:
0  0
1  1
2  1
3  2
4  3
5  5
6  8
7 13
etc ...
Message 7 of 19
(8,804 Views)
thanks for the build array tip, but no i haven't found a way to make the n input values show up in the first column. What am I missing?
Message 8 of 19
(8,770 Views)
hello?, I've tried to make a for loop which I think would help make the inputs show up on the 2d array, but I think im not doign something right cause it affects the 2nd column, and both of them have the same numbers, so that cant be right
Message 9 of 19
(8,759 Views)
Post your VI so we can see what you are doing.  There is no way we can guess in what way it is wrong without seeing it.
Message 10 of 19
(8,747 Views)
