field fox microwave analyzer version N9918A and LabView
I have Labview 2015 , but no experience with it,I have a project implemented on labview,it consist of wide band spectrum sense code.
-the first question is :
-if I make a spectrum scan   for a signal generated from a signal generator using the labview and usrp 2932,is it possible  saving this data as a file in the labview?
-and how to use this data in the microwave analyzer,in another word how to make connection between the labview and the(field fox microwave analyzer version N9918A ) ?
I would highly appreciate any help. Thank you very much for your time.
(4,638 Views)
(4,629 Views)
Accepted by topic author DOHAAACB19619
You're in luck, there are an incredible amount of learning resources out there for beginning LabVIEW users. I would recommend searching these forums for questions similar to your own in addition to browsing the built-in examples in LabVIEW. Those examples can be found at Help > Find Examples.
Saving data is a very common function to add to a LabVIEW application. Here are two resources I would recommend reading to learn more about it.
Automate Saving and Reporting Data with LabVIEW: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1k3CAA&l=en-US
Best Method for Saving Data to File?: https://forums.ni.com/t5/LabVIEW/Best-Method-for-Saving-Data-to-File/td-p/1178257
As for the second question, I have never worked with that piece of hardware before. I'm not sure what format data needs to be in for the field fox microwave analyzer to read properly. I would recommend searching for a history of people interfacing between LabVIEW and that device, or possibly consulting the manual provided by the manufacturer. Many 3rd party devices have LabVIEW drivers on their website.
Happy learning!
(4,592 Views)
thank you very much  BrandonC1, you are helpful ,I relay benefit of your solution ,it help me solving my problem ,I Hope you will help me if I face another problem if you don't opposes:
(4,524 Views)
I definitely don't know everything but I'll do my best to help!
(4,513 Views)
