field point, device timed out
I have difficulty to connect FP-1601 to my computer using MAX. "The connection to remote device timed out." message pop up everytime. Any suggestions?
Thanks.
(2,788 Views)
If you already assigned an IP address to your module, try pinging it first (Start>>Run>> Ping x.x.x.x).
If you don't get an answer the problem is there. A common cause for this is using a wrong cable. If you are connecting directly from your network card you will need a cross cable.
Another potential problem is firewall blocking. You need to allow MAX in your firewall.
Yet another is not being on the subnet as the device and having the subnet mask block your communication.
Did you manage to talk to it in the past?
Does it have an IP address?
___________________
Try to take over the world!
(2,782 Views)
