fieldpoint communication labview RT
I have 2 fieldpoint controllers (FP1600,FP2000)with their own acquisition modules. They are connected on a PC by a HUB. When i use labview RT, i don't see FP1600 modules tags from the FP2000. How can i use fieldpoints tags created on the FP1600 from an application located on the FP2000 ?
Best regards.
(2,889 Views)
With NI-FieldPoint 4.0 and earlier, you can not use the FieldPoint Read/Write/Advise VI's with FieldPoint tags that are not located on the bank directly connected to the FP-20XX controller. Instead, to access tags on other ethernet network modules, you need to use DataSockets to connect to the published items. For serial modules, you need to use the FieldPoint Optomux VI's. I do not know if FieldPoint 4.0.1 has added the ability to communicate with non-local tags on RT controllers.
Aaron
LabVIEW Champion, CLA, CPI
(2,889 Views)
