file attributes hidden and OS folder information
I want to save a file in hidden and read-only. Then, open again and write some data (after changing the file attributes.).
How to change the file attribute in LV8.2? I can't find out any related function and manual.
I found some postings for this problem, but it related to OPENG library.
Should I install some additional library?
Futhermore, I would like to how to read the OS directory(ex. c:\windows) from Windows property.
How can I do for this job?
Lee
메시지가 08-01-2007 06:04 PM에 labmaster에 의해 편집되었음
(2,967 Views)
Check out the "set permissions" and "list folder" contents using the built in Advanced File Functions. Not sure you can hide a file with LabVIEW however.
(2,951 Views)
