file copy
Hello everyone,
I have to open a single file from a selected source folder, modifiy it using Notepad and then copy it to a destination folder (usually different from the source one).
Also, I have to back up some files, so I want to be able to select multiple files or to select a whole folder, and then to copy it into another folder. I attach the vi.
I think my coding is redundant, but I need to configure the "copy" objects and the paths in slightly different ways. Any suggestion for a more elegant implementation?
Further, when I try to copy a folder into the same location, even if I select "overwrite" I get an error 7 (I attach the screenshot). Any ideas on this? Thanks
(3,378 Views)
Try to share the code in LV 2017 or Lower.
Presuming that you will be modifying the programmatically, In that case read the content from the file modify it and save as different file Name, in that case you will have back up file as well as modified file.
Can repeat same for multiple files in a folder as well.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,375 Views)
I attach the code in v 2016
(3,325 Views)
Hi Davide,
Put a wait statement in the loop: no need to spin as fast as possible!
Your Stop button is missing its label: NEVER delete the label of frontpanel elements!
How are you trying to "copy a folder"?
(3,320 Views)
Thanks for your suggestions,
but my point is: there are two case structures, which are pretty much the same, beside the configuration of "browse" options.
Can I someway do with just one case, properly configured?
(3,315 Views)
Hi Davide,
Use the FileDialog function to browse for files/folders:
  1. place it in your block diagram
  2. open its frontpanel (its an ExpressVI)
  3. copy the subVI inside to your blockdiagram
Now you have a FileDialog function with a "browse options" input and you programmatically decide which kind of options you allow to browse for…
(3,287 Views)
