file dialog express VI - replace or create with confirmation option
Does anyone else here think that this express VI should have built in replace or create with confirmation option like the Open/Create/Replace File function?
Don
Message 1 of 11
(5,788 Views)
I think that all Express VIs should be obliterated, except for Elapsed Time express vi. Smiley Wink  Express VIs were invented to market Labview as a rapid development language.  Now its reputation is such that we developers are expected to produce in an unreasonable amount of time.  Express VIs are very limited compared to discrete functions.
Be a real programmer and use the discrete functions like Open/Create/Replace.  It has the option you are looking for.
- tbob
Inventor of the WORM Global
Message 2 of 11
(5,782 Views)
I agree that many Express VIs have limited functionality but in this case, the Express Dialog is nothing more than a wrapper around the old file dialog function and an easy way to configure it. It's purpose (both old and new) is to give more options than the Open/Create/Replace such as pattern and start path. When doing a file write, it would be appropriate to do a Open/Create/Replace after the dialog.
Message 3 of 11
(5,775 Views)
The File Dialog Express VI is one of the only, if not the only, express VI I use.  Let me tell you why I started using it awhile back.  The 'old' version of Open_Create_Replace File.vi (~ < LabVIEW 7.1/8?) allowed one to specify pattern and default name, whereas the newer version does not.  The file dialog express VI allows these options also.  So yes, the best thing is to do a Open/Create/Replace (current version) after the express dialog after Dennis suggests.
Don
Message 4 of 11
(5,756 Views)
21237i4DB9541F413D5D9C
You can find the old open\create\replace file.vi here  "......\National Instruments\LabVIEW 2010\vi.lib\_oldvers\_oldvers.llb\Open_Create_Replace File.vi" Using the old File Dialog function.
The help for the old File Dialog is somewhat funny. As it claim is is not supported any more, but is still the core of the new Express VI. The only thing they did was to remove it from the palette. WhyTFR30E.gif
The good thing is that in the Labview 2010 information they do not mention Express VIs at all. In the 2009 version they bragged about X new EXpress VIs. So perhaps after many years of complaining they do see the fact that Express VIs are not so great after all.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 5 of 11
(5,748 Views)
Ultimately, the best space-saving solution is to go back to the old version of Open/Create/Replace - not sure why this one has been retired.  Good find.
Don
Message 6 of 11
(5,743 Views)
One of my pet peves with express vi's is that they take up too much room.  However, that can be solved by changing the view to an icon style.  Still, if I need the extra functionality, I will use the old version of Open_Create_Replace.
Large                          smaller              smallest (but not by a lot)
21277i1997EA09173CBD30
- tbob
Message 7 of 11
(5,729 Views)
How about that.  The File Dialog express vi's block diagram is a call to another express vi, subFile Dialog.vi!!!!  Smiley Surprised  One express vi calling another express vi?  Why couldn't they just put the old Open_Create_Replace inside the first express vi?
21281i5C8281D60D98183D
- tbob
Message 8 of 11
(5,724 Views)
21283i311654FDF681447E
I guess we could make a subVI out of the left side if we really wanted to if we were not able to get access to the retired version.
Message 9 of 11
(5,720 Views)
Hey all,
I think this is a pretty valid concern. It would be a good thing to take to the Idea Exchange to get on the radar of R&D and other users.
NI Idea Exchange - NI Discussion Forums
http://forums.ni.com/t5/NI-Idea-Exchange/ct-p/ideas
About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  3. Watch as the community gives your idea kudos and adds their input.
  4. As NI R&D considers the idea, they will change the idea status.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Best,
Chris LS
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
Message 10 of 11
(5,702 Views)
