file dialog with multiple custom patterns
I am in need of being able to user select multple file patterns (*.bin, *.exe...) in a file dialosg similar to the express File Dialog VI where it lists the directory and allows the user to select multiple files from a windows dir listing.  The express VI has a patterns input that takes  multiple patterns separated by a semimcolon but there appears to not be a way of providing a ring control for file type and letting the user select the pattern that he wants to filter the directory listing with.  I.E> > If the user wants to only load files that are *.bin, he only wants to view them in the listing.  How can I do this without mutliple dialog boxes?
Message 1 of 12
(9,207 Views)
Can you post your code?  That might help some.  Also, you could try a Combo Box to output strings, use a Case Structure for filtering selections, etc.  There's a lot of ways to do it.
Nathan - Certified LabVIEW Developer
Message 2 of 12
(9,204 Views)
I am merely looking to see if there is a way to use an off the shelf type of control that I dont know about.  Right now I am just looking at using the file dialog express VI.
Message 3 of 12
(9,202 Views)
Off-the-shelf might be something like a list box that allows multiple selections.  Or you could drop a cluster of booleans on the FP and parse the selected file types and place ;'s between them.  You could have multiple string controls that the user inputs the file extension and then you programmatically insert a ; I can't think of something off-the-shelf that easily does what you are looking for, these suggestions require a little bit of programming but should get you off to a good start at least.
This is the approach for choosing any desired types from a list.  If you want to choose only one, use a ring or combo box or enum...  Much simpler when only choosing one of many.
Message 4 of 12
(9,192 Views)
You mean something like this:
Wire the discription of the first type of file into the "Pattern Display" input (I.E., "Word Files")
Then right click the format string and enable "codes display"
Then try something like this
"*.doc;*.docx)\00*.doc;*.docx;\00Bitmaps\s(*.bmp)\00*.bmp\00\00"
Message 5 of 12
(9,177 Views)
Don,  thanks I tried what you said but i got a labview crash error.  Maybe I was doing something wrong here.  Can you make sure that I am doing what you said to?
Message 6 of 12
(9,172 Views)
Your format string is incorrect.  Change the ?00 to \00.
Smiley Wink
Message 7 of 12
(9,169 Views)
U da man -Thanks.  Thats exactly what I wanted...Smiley Very Happy
Message 8 of 12
(9,165 Views)
Any leads as to where this string syntax is documented would be beneficial to my cause.
Message 9 of 12
(9,153 Views)
The first time I saw it (from NIs side) was from one of Darren's Weekly Nuggets:
http://forums.ni.com/ni/board/message?board.id=170&message.id=497502&query.id=3663527#M497502
That dialog, I believe, is hooked from the Windows API so the best place it is documented are external sites dedicated to Windows API programming.
Example:
http://www.winprog.org/tutorial/app_two.html
ofn.lpstrFilter = "Text Files (*.txt)\0*.txt\0All Files (*.*)\0*.*\0";
This is roughly the same type of format string.  We just need to enable special codes display to place in the nulls.
Message 10 of 12
(9,150 Views)
