file name
How do I go about creating a file, setting a default file name and not allowing the user to change it?
(2,891 Views)
Hi b_lee:
Use a path constant, in the case you don't want to change the location of the file. It's located under the File I/O palette under File Constants. Just write down in the path constant the path and the name of the file and you're done.
Regards.
Robst.
Robst - CLD
Using LabVIEW since version 7.0
(2,880 Views)
I put the path constant but it still prompts me for a file name.
(2,868 Views)
You should probably describe your application in a bit more detail (what subVIs you are using, e.g.) or perhaps post a simple VI demonstrating the problem if you need more help.
-D
(2,861 Views)
