file not found on load
Hi all,
Running windows 7, LV2011
Trying to do a speech recognition project using microsoft speech recognition functions.  The application i found on decibil, here , requires the system.speech.dll from the .net framework.  Now the problem happens when i direct labview to the path of my system.speech.dll, which looks like this  C:\Windows\Microsoft.NET\assembly\GAC_MSIL\System.Speech\v4.0_4.0.0.0__31bf3856ad364e35\system.speech.dll
i get this error everytime
Any thoughts?
-Matt
(2,984 Views)
Did you install Speech SDK ?
(2,971 Views)
I believe it comes installed on windows 7 computers.  I was able to get the VI to work by reselecting result method in the speechrecognizedeventargs node.  I think they may have had the wrong version associated with the file.  Still doesnt explain why it wouldnt find that file though.  Im going to try to repurpose this VI to recognize a voice pattern.
-Matt
(2,960 Views)
