file path default
How can we setup a file path so as by default it is not empty, in other words when running the VI, it would not ask to specify a file.
Message 1 of 9
(10,589 Views)
Hi RJP,
try this: right click on the control and select "Data Operation -> Make current value default". Hope this helps.
Mike
Message 2 of 9
(10,587 Views)
You can either pass the file that you want as a constant or through a control, or try feeding "current vi's path" or "default directory" constant from Flile I/O --->File Constants.
If you can attach your VI and be slightly more descriptive, we can perhaps better help you.
Best,
Santiago
Message 3 of 9
(10,571 Views)
Thanks guys, worked for me.
Message 4 of 9
(10,546 Views)
I have 2 problems.
1. My program keeps ignoring what I put in Start path on a global path variable. It goes to the desktop nomather what. It worked at first but then just suddenly stopped working. So I coded it with a constant (bad solution =/).
2. When I code the path I wanna code it like this: "current path of running vi or program\data" but I dont know how to type that in.
So I dont want it to be eg. "C.\Labview\CE v1.0\data" so that if the folder is moved or renamed the coding wont work...
Anyone who has any answers?
Cheers
Message 5 of 9
(10,290 Views)
Y cant you use this icon
Message 6 of 9
(10,284 Views)
Wops that was what I was looking for. Stupid me trying to write some expression for it =). Thx
Message 7 of 9
(10,257 Views)
Nothing stupid mate.We are all here to learn something new everyday!!!
Dont forget to rate a good answer
Message 8 of 9
(10,246 Views)
Thanks mike
Message 9 of 9
(8,249 Views)
