file path
Good morning
I like to set a file path that defaults to c drive in any computer.
Pls give me some guidance
(2,839 Views)
Veeru wrote:
[...]to c drive in any computer.[..]
Does that mean that the application should run on different systems (individually) and each should default the local c-drive?
Norbert
Norbert
Expert: Geometry
(2,834 Views)
Thanks Nobert
I have solved the problem
(2,824 Views)
